Most power from std RST?
Mike it will need a good cooler and a bigger turbo- just anyold cossie turbo.
Best bet is just to chip it for some fun and cut a hole out in front of the standard cooler.
Will look a bit shitty but it will work
J
J
J
J
I reckon we should organise a 'Ł1000 RS Turbo Track Car project', where entrants must buy and prepare an RS Turbo for the track for under Ł1000 (including buying it) and the winner is the fastest around the track!!
Quality idea I think!!
Originally Posted by EvilFranky
Was always under the impression a standard RST head won't flow enough air for 200bhp.
my mates car made 197 at 18psi on a totaly standard (brand new main dealer) engine with a filter exhaust and chip. Its been argued before that it didnt and the rolling road was wrong cause to get that power a 5th injector is needed but the print out said 197bhp so thats what i belive.
I state FULLY working
at about 46psi though wasn't it??
PMSL. I made 250bhp and over 150mph on a Standard head!!
PMSL with the 5th injector rubbish
Jon, spike of 32psi!!
held 26psi AFAIK
I have a 5th injector on mine (ERL MF2 Driver and Dark Green Injector) only because metering head I have doesn't fully operate as it should
held 26psi AFAIKI have a 5th injector on mine (ERL MF2 Driver and Dark Green Injector) only because metering head I have doesn't fully operate as it should
Max you'll get with jsut a chip and actuator change will be 175bhp and about 200lbft running about 14psi.
I added a PE head and cam and made 195bhp - that was a sweet conversion! hardly any lag and a huge power band!
i bought a xr3i with rst lump (fully working NO smoke!!!) for 100 quid,have since acquired a bayjoo chipped ecu,d/v(dont like them but cant get chatter and need a noise!),it came with a stainless exhaust(dunno the make but no middle box dont look restrictive!) bleed valve,px induction kit from a mate for free,my group a coil off me old cossie,c59c's off me old cossie,needs a new actuator but it goes quite well! is completely stripped now too!only 2 seats and a dash left!gonna try and make it 200 ish bhp,only spent 100 smackers still! so i reckon i could have it all done for 300 odd quid all in!
so what else do i need?gonna get a -31 then turbn the boost up to about 18-20 psi i suppose!do i need a cam?if so whats best?or can i get mine reprofiled?and i am getting a pace cooler for nowt too!
Well, actually it was as James stated. I ran 26-28psi held and sometimes saw spikes of up to 32psi.
That was also on a bog standard bottom end, except that it was fairly low comp.
Others have said that you can get to 175 bhp with a Chip and -31 Actuator. I disagree, I think you also need a GOOD Stainless exhaust, like a Mongoose. An Bigger Intercooler is required to get beyond this point. Also, 200bhp is difficult without at least a Stage 2 Turbo.
Oh yeah, it MUST also have the Fumes Mod.......
Originally Posted by AndyRST
I could quote what BHP mine has made at what PSI but no-one ever believes it so no point really
But engine condition seems to make a big difference to power output
Also it is a quick car on the road.
Originally Posted by NEOŽŠ
stupidly???? i think not..its been running this boost for a year safely
Pebbles is a 1.9 tho, so it would go well
Mine made 200 horses with standard head and cam plus the standard turbo. Gearbox is rattly tho
As standard, best you can muster is 170 bhp with about 14psi, anything above that on the standard cooler and act's will go through the roof
Dan, its a 1.6
