1.9 cvh tallblock rod length
Old Apr 2, 2008 | 09:55 PM
FULLBORE's Avatar
FULLBORE
Default 1.9 cvh tallblock rod length
does anyone know what the size/dimensions is of these rods??????thanks
Old Aug 11, 2009 | 08:50 AM
Escorvette's Avatar
Escorvette
after little searching, i found out that 1.9 rod lenght is 5.1945(131.94mm). i'm not 100% sure about this cause, 1.6cvh rods are the same lenght. If you are planning to fit 1.9 crankshaft to 1.6 block, you'll need lower pistons cause 1.9 deck is 0.16732(4.2499mm) higher that 1.6.
Old Nov 17, 2017 | 08:09 PM
Dhale's Avatar
Dhale
Are all cvh cranks the same are the interchangeable
Old Nov 18, 2017 | 08:51 AM
smiley's Avatar
smiley
The 1.9 cvh is 88mm crank and pistons 83mm i ran one these tall blocks
Old Nov 18, 2017 | 01:39 PM
Dhale's Avatar
Dhale
Default Crank
Smiley would a 1.6 crank fit a 1.3 block
Old Nov 18, 2017 | 03:55 PM
smiley's Avatar
smiley
Sorry mate i wouldnt know just knew the sizes for the 1.9 i had they are american parts
mk3ste
Oct 17, 2021 10:09 AM
sridgett
13
Sep 27, 2015 06:03 PM
little bram
Sep 27, 2015 07:45 AM
Russp
Escort Range
Sep 18, 2015 07:39 PM
