s2 gearbox oil
Old Apr 2, 2008 | 07:58 PM
kevbnicpp's Avatar
kevbnicpp
Default s2 gearbox oil
what to use and how much?
Old Apr 3, 2008 | 12:34 AM
wildheart's Avatar
wildheart
Not sure on how much though.
Old Apr 3, 2008 | 07:24 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
3.1 litres. I usually pump it in with an oil syringe as it will start to run back out, making you think its full, once you get 2.5 litres in there, but you really should try and get the whole amount in and pumping it will help that.
Old Apr 3, 2008 | 06:11 PM
SWITCHBLADE's Avatar
SWITCHBLADE
Passionate about fords
without taking the gearbox out, if draining the box to just change the oil theres no way of draining it completely dry is there ???. ie some old oil stays in the box due to the height of the filling hole ????. the reason im mentioning it is when filling up my box after draining, the box only took around 2 ltrs, i rang cts to check the capacity and they said there was a possibility there could be some in there when drained, maybe in the diff etc ????.
dave
TPM961
Jan 15, 2018 10:50 AM
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Flateric_2002
Sep 15, 2015 08:41 AM
Adam Graham
Sep 6, 2015 06:04 AM
