different pistons request pics
Old Apr 1, 2008 | 03:30 PM
b_kennedy's Avatar
b_kennedy
Default different pistons request pics
looking for pictures of different pistons. Also a pic of a standard one Would help too if possible. I have a pic i would like to know what it is but unfortunately cant upload pics at the moment.
Many thanks
Old Apr 1, 2008 | 05:45 PM
Mr.T's Avatar
Mr.T
Here a std one
Old Apr 1, 2008 | 06:01 PM
Moonie's Avatar
Moonie
A standard broken one...
Couple of pics i have of a standard set that have had 1mm machined off the crown...
Old Apr 1, 2008 | 08:22 PM
b_kennedy's Avatar
b_kennedy
Originally Posted by JeroentjeRS
Here a std one
That helps me alot guys. Thanks for the pics. I have standard ones then, which is what I was trying to find out!
Mine look like the ones in this pic. Does that mean they are ok or could there still be more damage?
Thanks again fella's
Old Apr 1, 2008 | 08:32 PM
Red_bull's Avatar
Red_bull
if they are in the block like on the pic of Jeroen, i would take them out and check the sides of the pistons, the sides can have damage that you don't see like that
Good luck
Old Apr 1, 2008 | 08:40 PM
b_kennedy's Avatar
b_kennedy
yeah still in the block. i never stripped a block before so i was trying not to lol. i will have to give it a go. any pics on wat to look out for? rings etc??? thanks
Old Apr 2, 2008 | 06:54 PM
Mr.T's Avatar
Mr.T
Mines had no damage at all mate. Just a bit dirty. Nothing wrong with it. And taking an engine apart isnt that hard. Just get the right tools. Its piss easy
Old Apr 2, 2008 | 08:59 PM
b_kennedy's Avatar
b_kennedy
ok. thanks fella! what am i looking out for? just general wear?
Old Apr 2, 2008 | 09:06 PM
Red_bull's Avatar
Red_bull
Yeah most of it is genaral wear, but maby there is a big burst or a crack.... I would always take the pistons out when you have your block open. Maybe you rebuild your engine for loads of money and then somethings goes wrong because of a crack of to much wear on your pistons..
Also you can check the lines in the block for the oil to come round the pistons to lubricate it (don't know how you call in it in english :'()
Old Apr 3, 2008 | 03:48 AM
Mr.T's Avatar
Mr.T
Just give it a hone and indeed look for cracks. Get new pistons rings, main and rod bearings,new waterpump,oil pump etc. Make sure you use the right tools. Torque everyting like the specs and you will be fine. Make sure the crank is good. get everything messured up
Old Apr 3, 2008 | 09:32 AM
b_kennedy's Avatar
b_kennedy
OK. Finally got some pics uploaded. Here's a pic of my block!
When changing the rods etc like you say, do I also have to change the bolts (like head bolts) or just use the same ones?
Thanks guys
Old Apr 3, 2008 | 09:39 AM
JamesH's Avatar
JamesH
New head bolts
Old Apr 3, 2008 | 10:13 AM
b_kennedy's Avatar
b_kennedy
i meant bolts for bottom end lol
Old Apr 3, 2008 | 07:53 PM
Mr.T's Avatar
Mr.T
you can reuse them. But if you want better ones just get ARP. But if you are on a tight budget like me you can use them again. Just torque them with the right spec
Old Apr 4, 2008 | 08:58 AM
b_kennedy's Avatar
b_kennedy
Thanks fella. Much appreciated.
Whats the best way to get the block out the car without a hoist??
Old Apr 4, 2008 | 05:57 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
Same way i did mine last night:
Support the engine on a block of wood with a jack underneath, take the mount off the wing completely, then undo the bellhousing bolts and remove the starter/alt etc. wiggle it all about for ten minutes until the flywheel end is pointing straight up in the air and the crank pulley is on the floor, then lift it out!!
jessie_rs
62
Aug 6, 2019 09:27 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
locum8
Sep 14, 2015 08:45 PM
ajamesc
Sep 8, 2015 06:51 PM
chris m1
Sep 7, 2015 08:02 PM
