boost controller
Hi, was wondering what type of boost controller people run with ? Been hearing shit about this bleedvalves and since I have one I must say I agree, the boost wont hold it self stable
yes so, give me some information ?
I dont like it when the boost peaks at one point then drops down a bit ...
Hi mate dont think many or if at all any cosworth owners run an electronic boost controller. Usually see them on the japanese cars..
Plus its not a plug and play option its needs setting up once fitted and depending on the controller it isn't really a simple thing to do.
Hope that makes sense
I run whith simple GREDDY BSpec2. Easy to install, easy to adjust, small and has some useful functions - easy switch between two preset mods, keep in mind peak boost, show last boost some seconds after you close the throttle, also you can increase boost at hi rpm if your boost droped at hi revs.
Sta1n1, this might help you, what car is it on?
https://passionford.com/forum/showth...ost+controller
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
