Escort Coss Voltmeter Gauge Not Working
Old Mar 31, 2008 | 07:50 PM
Cossie-Lee's Avatar
Cossie-Lee
Default Escort Coss Voltmeter Gauge Not Working
Hi all, My voltmeter gauge has stopped working on my escort cosworth, i have checked fuses and they are getting a live on both ends of fuse, i have also changed the relay but this hasnt helped.
Does anyone have any suggestions on how to get this working???
Cheers.
Old Mar 31, 2008 | 08:00 PM
kjc300's Avatar
kjc300
here's the wiring diagram if it helps....
Old Mar 31, 2008 | 08:39 PM
escossie's Avatar
escossie
I had the same problem about a month ago & it was the relay on the main fusebox for the voltmeter, put a new one in & its been perfect since. From what i can remember it was a yellow relay on the right of the fusebox i think it was the second relay down from the top right corner as you look at it.
Hope this helps,
Graham
Old Mar 31, 2008 | 10:41 PM
Cossie-Lee's Avatar
Cossie-Lee
Thanks for the replys guys.
Kjc300 - Cheers for the diagram mate but it goes straight over my head, if i knew the colours of the wires and where they go in/out of the fusebox then id probably be able to check them.
escossie - I already checked the yellow relay and replaced it with 3 others but still no joy, im also a live on one of the pins, but thanks for the advice mate.
Forgot to mention that both the boost and oil pressure gauges work fine, so it might be the gauge itself. Paid Ł300 for a brand new fusebox in the hope this would sort out my electrical problems.
Anymore help would be gratefully appreciated,
Thanks, Lee
Old Mar 31, 2008 | 10:55 PM
kjc300's Avatar
kjc300
Check fuse 2
Check fuse 19
you've already checked/swapped the relay
The wire colours are labelled on the diagram, however easy way to check.....
Remove centre pod
get the plug with the 5 wires
with a multimeter set to volts, put one probe on the RED wire (pin 1), and the other probe on the BROWN wire (pin 2)
switch on ign to pos II or start the car, doesn't matter.
you should have 12v or 14v depending on what you did.
This will check if you have power to the gauge.
Old Apr 1, 2008 | 08:27 AM
escossie's Avatar
escossie
Are you sure you changed the correct relay as the diagram i had showed it on the top left of the fusebox but it was on the top right second relay down.
Vincereese
Jun 1, 2023 09:14 AM
steerfromdarear
28
Jan 29, 2016 06:14 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
