amal valve
just wondering where to put this?? just been rebuilding my saph and not sure where this goes...
also im getting a bleed valve does that mean i can get rid of the amal valve or do i need to keep it?
a pic of a 2wd saph engine bay would be very handy!
thanks
raz
thanks
raz
Ah right in that case you'll need to buy a bracket that bolts to the slam panel m8,as for the pipes type in "amal" into the search facility and it'll show you what pipe goes where m8.
https://passionford.com/forum/showth...t=fitting+amal
found a link...ok dont want to sound stupid - inlet C where does this attach to the intercooler? similarly ive got a knn filter on mine so what hpns to inlet R?
raz
raz
Amal valve is at the front in the middle. Mine is held on with a tie wrap I think. Directly in front of the left hand cam pulley in this pic:
And pictured here. I think mine sits on the intercooler.
Charlie
Charlie
C = Compressor/turbo
W = Wastegate/actuator
R = Return/air filter, though this one can easily be left off with no problems.
If going stage three or above will most likely need to drill out, or remove RESTRICTOR in end of amal valve pipe.
I just srewed a wood screw into mine and it popped out easy enough.
