gauges dead..??
Old Mar 30, 2008 | 02:16 PM
fezzajsy's Avatar
fezzajsy
Default gauges dead..??
just took the cossie out for a blast n noticed that the fuel,temp and rpm gauges dont work..speedo is fine though..anyone got a clue?
cheeRS
Old Mar 30, 2008 | 02:25 PM
KSA-Cossie's Avatar
KSA-Cossie
Check fuses or connectors behind the clocks.
Old Mar 30, 2008 | 02:27 PM
fezzajsy's Avatar
fezzajsy
will do thanx..
Old Mar 30, 2008 | 02:30 PM
KSA-Cossie's Avatar
KSA-Cossie
Old Mar 30, 2008 | 06:36 PM
I'd also check earth connections(clocks) as may use more than one.
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
