xr2 keeps cutting out
Old Mar 29, 2008 | 05:48 PM
marksrsorion's Avatar
marksrsorion
Default xr2 keeps cutting out
only just started to do it, will run for about 5 mins until warm then will cut out, but leave it for a couple off minutes and it will start again, any help would be great need to get sorted as still need to drive it for a week until the new engine gets put in.
thanks
Old Mar 29, 2008 | 07:44 PM
mechanic28's Avatar
mechanic28
cracking cars these fella!is it a mk2 carb one?
Old Mar 30, 2008 | 10:27 AM
benny f's Avatar
benny f
if its got an electric fuel pump could be the fuel pump relay as i had this problem with a mates volvo.
Old Mar 30, 2008 | 10:45 AM
XR2's Avatar
XR2
XR2 without an "i" should be a carb'd one, came with mechanical pump.
Had the same problem. Hole in a diaphragm. Buy a service kit (Ford sells them, Burton also, cost 22.50 for DFT @ Burton, same price for the TLDM) and it all should be fine again.
Second thought: could also be the cold start thing...
Old Mar 30, 2008 | 04:25 PM
marksrsorion
went and ordered a new carb and full head set as i'm about to put on my stage 3 head next week, also wheres the timing mark on the crank pulley ment to be on the 0?
Old Mar 30, 2008 | 04:31 PM
XR2's Avatar
XR2
there's a timing mark on the rear (engine) side of the pulley, but this is not very useful...
Put on the lower cover for the cambelt and the pulley for the alternator pulley.
Old Mar 30, 2008 | 05:40 PM
mechanic28's Avatar
mechanic28
timing mark for the crank there is a mark on the oil pump!line that up with the mark on the crankshaft pulley!will be pointing striaght up!same as the camshaft mark
Old Apr 1, 2008 | 03:21 PM
marksrsorion
thanks for the help been really useful, all timed up now running sweet as a nut.
mechanci28 yeah xr2 on a f plate 1.6 cvh carb, got a stage 3 head waiting to go on and twin 40s getting rebuild, just got to weld some new inner sills thou as these are pretty crap.
Old Apr 1, 2008 | 09:58 PM
mechanic28's Avatar
mechanic28
cool done all that to my xr2 but with a stage 2 head!take it u got dcnf carbs?pain in the ars tho !as u have to keep balancing them!
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
Fudgey
21
Sep 30, 2015 06:19 PM
mondeomark
Sep 28, 2015 06:28 AM
