2wd saff & 3 door differences ?
Old Mar 28, 2008 | 09:31 PM
Sideways_Sierra's Avatar
Sideways_Sierra
Default 2wd saff & 3 door differences ?
I may be tempted by a 3 door a mate has, but wondering how different the 3 door and the 2wd saff are?
In terms of, is the whole running gear inter changable, and steering, column etc, rear beam etc
not fussed about interior and obviously doors/glass etc
just interested in the running gear differences
cheers
Old Mar 28, 2008 | 10:14 PM
lamb chops's Avatar
lamb chops
they are the same mate appart from some rollbar changes and the front hubs as far as im aware
Old Mar 29, 2008 | 07:09 AM
As said pretty much the same, apart from front and rear roll bars/hubs/rear arms.
Old Mar 30, 2008 | 01:33 AM
AndyPen's Avatar
AndyPen
Are the front struts identical then lads?? Anyone got any more info or pics of the hub differences too??
Old Mar 30, 2008 | 05:37 AM
The difference in the front hubs were that they used a different fitting technique for the TCA.
The front ARB had a different length causing LESS castor on the 3 door as well.
Struts were identical although damping rate was changed from sapphy to 3 door.
Old Mar 30, 2008 | 12:41 PM
Mike1's Avatar
Mike1
cheers
These are some of the changes from 3-door to Sapphire 2wd made by Ford.
Obviously the 4-dr shell was stiffer which has to be taken into account.
Spring rates went up from 106 to 118lb/in at the front and 263 to 286 lb/in at the back.
Damper rates were made softer in bump and stiffer in rebound.
ARB was increased to 16mm on back
Castor increased by over one degree
Camber made fractionally more negative
Kingpin inclination made slightly greater.
Front knuckles re-designed to lower the front roll centre from 144mm to 70mm
Work was also done to rid the tendency of the 3-door to "pitch" front to rear.
Much of the work above was done to create a less "nervous" car and for it to have better straight line stability
mike
Old Mar 30, 2008 | 06:18 PM
155lee's Avatar
155lee
so is it a good idea to convert a 3 door to sapphire front suspension?
Old Mar 30, 2008 | 06:31 PM
I always go the other way, as much prefer the 3 door set up.
Old Mar 30, 2008 | 07:14 PM
AndyPen's Avatar
AndyPen
are spring rates the same then Tab? I have a spare three door strut set and my saff is sagging on the drivers side. Could be spring or shock I guess - so was planning to swap them.
Old Mar 30, 2008 | 07:20 PM
kev 3dr's Avatar
kev 3dr
Had a chat about the hub difference's yesterday with the Diva, Sticky and Nash,
apart from the obvious of 3dr's having the pinch bolt setup on the TCA these where originaly specced for motorsport use where as the Saph was just built as a quick saloon car.
Old Apr 13, 2008 | 05:40 PM
Sideways_Sierra
Thanks for the inputs chaps/chapess's
so would 3 door front hubs fit on a 2wd saff, if they are supposed to be better ? But better in what way?
Old Apr 13, 2008 | 06:36 PM
3 door hubs fit on with the correct lower arms as have done that myself.
Turn in was a LOT sharper, grip a LOT better, with the same toe and tyres.
Old Apr 13, 2008 | 11:39 PM
Sideways_Sierra
interesting, cheers for that, will have to sort out some lower arms now and i take it i would need the 3 door front ARB too?
Old Aug 23, 2008 | 08:42 AM
Harris.'s Avatar
Harris.
2wd saff front roll bar fits a 3 door, handles better too
Old Aug 24, 2008 | 12:46 AM
mechanic28's Avatar
mechanic28
thought the best set up was 3 door rear and sapp set up on the front?
Old Aug 24, 2008 | 12:51 AM
Kverna's Avatar
Kverna
Virgin-popper
Other way around isn't it ?
FlashRS
13
Aug 31, 2015 06:02 PM
saph in dorset
Aug 14, 2015 10:10 AM
COSWORLD
Aug 14, 2015 07:40 AM
Old ford
Jul 31, 2015 06:50 AM
