AFR problem with stage 3 chip
Hi,
I've recieved a stage 3 chip from PTS Motoring , 3 BAR Map , Greens, and RS 500 Cooler.
The boost was recomendet at 22PSI and when I have checked the AFR it was over 14 , so turn the boost back to 1.2 bar (and have now 12,5 AFR).
Please Post your AFR's for more information is it normal to drive with 12.5 AFR , because that wath i hear is under 12 on high RPM, the injectors are brand new the fuel pump is OK , what could be the reason for going lean.
Please Help
Please Help
Id check the voltage at the fuel pump; to be honest you are better off re-wiring the fuel pump with a direct feed from the battery.
Id also get a 044 pump to be on the safe side
while you are there changes the fuel filter as said by the bloke above
Fuel pressure should normally be around 3 bar idle vac on, around 3.7/3.8 with vac off, but as said check with chip supplier or instruction sheet(with chip) and set at what chip supplier intended though most tend to keep std pressure.
A pump rewire/relay is certainly a good idea, but you do NOT need to use cable big enough to start the QE2 like some think.
JK12
33
Apr 26, 2021 12:09 PM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
