Escos Fuel Pump Questions.
Hi, this might sound a bit stupid, but where are the big turbo escort cossie fuel pump relays situated?? I was told they are in the engine bay but have also been told they are on the fusebox, which is correct??
And another question, when you turn on the ignition and the fuel pump primes it should switch off after a couple of seconds, what is it that controls the pump to switch off?? is it the ECU or the relays??
Thanks in advance.
Thanks in advance.
JK12
33
Apr 26, 2021 12:09 PM
