fuel pump mnt rubbers
Has anyone changed these rubber mountings what go onto the pump carrier and join to the main pump/filter frame. Think there is 3 off round rubber mountings with a thread out each end and secure with nuts.
Mine av all broke free so pump is rattling around inside the main frame.
I fitted a new grp A pump a while ago and had to cut the pipe down from tank as was too long with new adapter on pump.
Maybe i not cut enough off and the pressure of the pipe pushing on the pump made the rubbers fail.
just sorting mine out now - they are still available from ford
bit of a pain to change though, you'll need to remove the whole cradle then drill/cut the remains of the old ones off
Yeah thought it maybe fun job
Got some on order for friday, had that bloody cradle on and off about 5 times
got a bit leak on tank to pump pipe 2 so hoping this is last time on my back. Cheers steve
JK12
33
Apr 26, 2021 12:09 PM
