explain play in turbo
Old Mar 24, 2008 | 12:30 PM
lewis_lisa's Avatar
lewis_lisa
Default explain play in turbo
when a turbo has bad wear there is play in the shaft, what way does the play go?
is it in and out the turbo or side to side? my turbo is not fooked but a m8 of mine destroyed his and want to know exactly what happens.
surely there will always be play side to side?
Old Mar 24, 2008 | 12:32 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
mine moves in and out with no smoke at all . i would have thought side to side would be bad?
Old Mar 24, 2008 | 12:54 PM
SWITCHBLADE's Avatar
SWITCHBLADE
Passionate about fords
i think its the other way round, in and out is bad, minimal side to side is normal on a used turbo. saying that my turbo was shot even though it had none of the above
dave
Old Mar 24, 2008 | 03:03 PM
RobL's Avatar
RobL
was wondering this myself, i recently noticed mines got a bit of side to side play in it but none in and out.is this normal?
Old Mar 24, 2008 | 03:14 PM
Rex Kramer's Avatar
Rex Kramer
Danger Seeker
i thought in and out was knackered and sideways was ok. both my turbos have a little sideways movement bun none in and out
Old Mar 24, 2008 | 05:28 PM
lewis_lisa's Avatar
lewis_lisa
ive just noticed mine has side to side play too. it doesnt smoke and doesnt hit the housing.
Old Mar 24, 2008 | 06:07 PM
picky775's Avatar
picky775
I thought all shafts had i bit of side to side as they float on oil??????
Old Mar 24, 2008 | 06:27 PM
adduk's Avatar
adduk
there should be no in and out play that is bad but you are ok for side to side but only a small amount as they fill with oil under pressure and take up the spare play.
Old Mar 24, 2008 | 06:35 PM
fuzzy's Avatar
fuzzy
my old turbo bought from that tuning 'god' Ace Performance had excessive play in all directions and smoked like a chimney
Old Mar 24, 2008 | 06:37 PM
flashpoint's Avatar
flashpoint
Hi, You will always have some side to side movement, this is quite normal as the bearings are fully floating... about 0.5 mm is normal, any more than that and the bearings are starting to wear.... in and out movement is controlled by the thrust bearing. any movement in this direction can be considered wear as it will cause the oil control rings (seal) to damage there seatings, and the end result will be smoke ...!!!!
Hope this helps....
Steve
Old Mar 24, 2008 | 09:18 PM
jonnyrsturbo's Avatar
jonnyrsturbo
is half man, half amazin'
side to side is okay, as it has no oil pressure in it, but in and out is bad!
Old Mar 24, 2008 | 09:22 PM
tomhs123's Avatar
tomhs123
Old Mar 24, 2008 | 11:40 PM
lewis_lisa's Avatar
lewis_lisa
cheers guys this has put a few minds at rest im sure. just had to be 100% sure i understood it. lol
Old Mar 27, 2008 | 10:07 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
there will be some play, its a floating bearing!!!!
check to soot/oil stains on blades and in intercoller feed pipe!!!
On rsts you can hear when the turbo's on its last legs as when its comes on boost it will make a small whining noise, very similar to a police siren in the distance!!
JK12
33
Apr 26, 2021 12:09 PM
Matt Baxter
Sep 16, 2015 08:30 PM
xrmalin
Sep 13, 2015 06:52 PM
kevin36
Sep 2, 2015 06:24 PM
