replaced head now oil mixed with water ? ??
Old Mar 22, 2008 | 06:03 PM
B1G_RST's Avatar
B1G_RST
Default replaced head now oil mixed with water ? ??
right ok doke,bought another rs with an engine knock, got it home,gt it started and relised it was the head,had spare head in my gargae so got on to replacin the faulty head,
took everything off put to tdc lined the head up,brand new head gasket and bolts, got every plugs n pipes back on, turned engine over by hand,all seemd ok dokey,
got it started was missing like fuck and not idling at all,while adjusting th dizzy cap i had the water cap off to let it self bleed,next thing i no the waters mixed with oil, mayo in oil cap, breathers all choked up also, took head back off but cldnt see anything wrong,got another brand new head gasket and wil rebuild again tomorow,
but any1 think of ther top of their head what it can be? ??
im kindoff puting it down to a bad gasket ?
im completly confused like
any help will be much apprecited
sean
Old Mar 22, 2008 | 08:20 PM
haz87's Avatar
haz87
Was the head skimmed?
Old Mar 22, 2008 | 08:24 PM
taz1787's Avatar
taz1787
Escort Cabriolet Owner
seconded should always get head skimmed before a rebuild
Old Mar 22, 2008 | 08:28 PM
kev_erst's Avatar
kev_erst
what was the oil like before you took the first head off? if it was mixed to begin with maybe something like rotten water channels in the block?
Old Mar 22, 2008 | 08:33 PM
jonnyrsturbo's Avatar
jonnyrsturbo
is half man, half amazin'
skimmed milk!
Old Mar 23, 2008 | 09:04 AM
B1G_RST's Avatar
B1G_RST
head wasnt skimed as i knew it was working perfect,oil/water was fine before head change,is there any daft thing i could of done wrong ?
Old Mar 23, 2008 | 09:15 AM
B1G_RST's Avatar
B1G_RST
Originally Posted by jonnyrsturbo
skimmed milk!
whats tht aww boot then ?
Old Mar 23, 2008 | 09:24 AM
Aaroncast's Avatar
Aaroncast
head wasnt skimed as i knew it was working perfect,oil/water was fine before head change,is there any daft thing i could of done wrong ?---------
above contradicts you innitial evaluation!!!!!!!!!
how did you ascertain it was perfect!!!!!!!!!-you said it was the head knocking!!!!!!!!!!!
unless you have proper facilities you cannot check only assume!
Old Mar 23, 2008 | 04:52 PM
B1G_RST's Avatar
B1G_RST
orite well i assumed and was right! it was the head as when i put on my spare working head it cleared,
anyway guys the cars running fine now,
cheers sean
Old Mar 23, 2008 | 06:17 PM
jonnyrsturbo
nice to here its fine now mate!
RUBY123
Oct 22, 2023 12:04 PM
j.hammond1
30
Oct 31, 2021 05:28 PM
YODI
Aug 30, 2015 01:12 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
ekjim
Aug 17, 2015 08:57 PM
