T4 &cossie management
Old Mar 21, 2008 | 07:45 AM
cressy's Avatar
cressy
Default T4 &cossie management
would a low comp steel bottomend be ok with a t4+cossie management on it?whats the pro`s & con`s car will going to be main used on track
Old Mar 21, 2008 | 08:10 PM
mattjones_81's Avatar
mattjones_81
cons......might be a tad laggy when tryin to get out the corners quickly!!!
Pro's.....will be bloody fast when it eventually comes on boost lol
Old Mar 21, 2008 | 08:19 PM
Gregs's Avatar
Gregs
think you will be ok with it, as long as you can get used to the lag.
surely if you can judge the lag you can use the accelerator earlier to get the power delivery when you need it?
Old Mar 21, 2008 | 09:16 PM
bonus_boy's Avatar
bonus_boy
as said above..
its just knowing your own car and getting ust to it...
Old Mar 21, 2008 | 09:21 PM
bad boy rs's Avatar
bad boy rs
Default t4
Not a t4 but i had a t34 on my low comp 1600 and the lag was terrible, but when it boosted it went like fuck
Old Mar 21, 2008 | 10:33 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
go 2.0 ZVH and it wont be so much of a problem?
Old Mar 22, 2008 | 06:43 AM
cressy's Avatar
cressy
only just finished build new engine mate it`s not even run in yet i thing if i told the missus i was putting an other new engine in it would be curtains lol
at least i can just say i`m buying a new turbo;-]
Old Mar 22, 2008 | 06:44 AM
cressy's Avatar
cressy
i`v have to slightly change the way i drive then mate;-]
Old Mar 22, 2008 | 06:59 AM
gus's Avatar
gus
who built the engine? tell them what you wanna be adoing in the car and they should be able to spec you a turbo to suit
Old Mar 22, 2008 | 08:54 AM
cressy's Avatar
cressy
me & my mate built the enging in his garage gus:-] were known has novice motorsport lol
Old Mar 22, 2008 | 08:58 AM
Johnny Knoxville's Avatar
Johnny Knoxville
I would of thought the GT Turbo's would be better?
Old Mar 22, 2008 | 08:59 AM
gus's Avatar
gus
then i would talk a turbo specialist and tell them your engine spec and what you want from the engine and they will spec it
no point putting mix match parts on, you will not get the best from them
Old Mar 22, 2008 | 09:23 AM
Gadget's Avatar
Gadget
Spanner monkey
Personally, i'd go for a 4x4 ( 60 trim ) cossie turbo with a .63 housing!
Old Mar 22, 2008 | 05:15 PM
Badman38's Avatar
Badman38
t4 1600 track car would be too laggy even when you learn how to drive it coming out of bends the revs woulkd be too low to spool the turbo up do as gus suggests get a turbo properly speced for the engine..
sean
Old Mar 22, 2008 | 05:49 PM
gus's Avatar
gus
sean
we will have to see about that sean
Old Mar 23, 2008 | 02:13 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Yours is slightly different Gus
You haven't just got a "T4 bolted to a steel CVH"
Old Mar 23, 2008 | 03:48 PM
mart rs's Avatar
mart rs
if you dint drive like a fairy you wouldnt need a big turbo!!
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
griffo69
Oct 4, 2015 11:58 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
deathrider666
Sep 28, 2015 06:12 PM
