View Poll Results: Which is better head gasket for a zetec turbo
Ford Std zetec black top multi layer steel
100.00%
cometic zetec black top multi layer steel for bores upto 87mm
0%
Voters: 2. You may not vote on this poll
cometic headgaskets - zetec black top discussion + advice
right i have been having a look for gaskets on ebay and came across someone selling cometic gaskets, now normally i would think that a gasket would be for one bore size only with a little room to play for a slight overbore / honing for new rings...
The link below is where i saw them
http://cgi.ebay.co.uk/2-0-Zetec-Blac...QQcmdZViewItem
Now it states it is suitable for every bore size upto 87mm, given the std bore size is aprox 84.7 mm thats a 2.3mm difference in the bore and the gasket fire rings.
Surely from this it would cause some problems? or is this completely suitable?
What would a gasket like this fair up to in a zetec turbo engine? or is the std ford MLS item better suited as i can get a cometic shipped over from the us for approx £37.50 plus shipping.
If it makes any difference i am fitting ARP head studs to the ZT i am building.
well the pistons i am getting from the us are a C/R of 9.0:1 which is a little higher than i had hoped, read the wrong thing and then ordered from a different place so if the cometics are slightly thicker then that would aid the C/R a little as just under 9:1 would be bit better and more room for error so to speak.
