going efi auto block
Old Mar 18, 2008 | 10:31 PM
tonyrally's Avatar
tonyrally
passionford god
Default going efi auto block
hey yawl need a bit of help im going efi using fiesta managment and a 2.1 zvh the block i have used aparntly came from an auto mondeo. iv heard that i cnt use the fiesta crank sensor with this.? can anyone shed any light on this or know how to tell if it is an auto block as it was a bare block when i bought it. also is there any other way round it ie... trigger wheel ect ect thnks for anyones help in advance tony
Old Mar 19, 2008 | 07:13 AM
Whoever told you that is talking crap.
The BLOCK is the same, they may well use a different sensor as the auto has a FLEX plate instead of a flywheel, so will be positioned differently, spacing wise away from the sensor.
So just put in your crank and firt the sensor, the crank differs ONLY in lack of a SPIGOT BEARING in the auto crank as there is no shaft from a gearbox to go in there so is not fitted.
Old Mar 19, 2008 | 06:37 PM
tonyrally's Avatar
tonyrally
passionford god
so will it be ok to use the cvh efi flywheel and sensor? just dont wana build the engine up an it be a waste of time? thanks for your help tabetha thanks tony
Old Mar 20, 2008 | 07:39 AM
If the CVH flywheel fits ok then yes it would be easy as if it comes to it, you can get a adjustable crank sensor anyway, so space it as needed by adjusting.
Sorry never done it so don't know if straight fit, but friend roosie has done loads and he had no special bits so std ford bits will fit.
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
AJC
Oct 1, 2015 06:47 PM
stevecfrst1
Sep 30, 2015 05:18 AM
20/20 vision
Sep 29, 2015 11:27 AM
