timing chains
Old Mar 18, 2008 | 08:19 PM
Peter ka's Avatar
Peter ka
Default timing chains
hi i got a ford ka and the engine is making tapping noise i had a full service done and had the tappets done but its made no difference but latey the noise is more a chain sound so could it be the timing chains and if it is can it be fix or is the car focked
Old Mar 18, 2008 | 08:32 PM
dave green's Avatar
dave green
any thing can be fixed, is it the old 1300 ohv engine or the 1.6 duratec
Dave
Old Mar 19, 2008 | 09:09 AM
Peter ka's Avatar
Peter ka
its a 1.3 endura
Old Mar 19, 2008 | 01:35 PM
dave green's Avatar
dave green
can be fixed, not to expensive on these engines
Dave
Old Jan 17, 2009 | 09:37 PM
RSturboJET's Avatar
RSturboJET
Can't Find 'em? Grind 'em
Tappets faces have gone from flat to a concave shape as well as a worn cam.
Old Jan 17, 2009 | 09:59 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
yes tappet face wear is very very common on these...
and then when you adjust them using a feeler gauge you are still left with a large gap in the middle, which is where it counts.
to do the timing chain is easy, the plastic tensioners can wear out, and the chain becomes slack. eventually the chain will then wear through the casing. to replace the tensioner you have to drop the sunp
ive done lots on these engines and when set up correctly they are very very quiet...its just that people tend to skip parts on the servicing, and the top end suffers badly then
Marino
Sep 12, 2015 11:10 AM
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
