WTF is wrong with my van, lol....
Old Mar 18, 2008 | 06:39 PM
Thrush's Avatar
Thrush
Irritating c........
Default WTF is wrong with my van, lol....
My van sounds fucked 55plate Ford Transit Connect, LWB, 35k on clock....
Strange sounds that sound like they coming from the front N/S wheel area - a constant grinding that gets louder/more so dependant on speed, and worse a "banging", "clunking" sound that happens under load ingear, in gear without load, in neautral - basically anytime rolling, but gets more frequent/faster the higher the speed - for example, it bangs around twice a second when doing 20-25mph, but at 70 it bands 4 or 5 times s second But not always, it's not 100% constant....
Anyway, jacked it up and took the wheel off. First thing I noticed is it's hard to turn the hub/brake disc as it feels like it's grinding against the pad/caliper. Having a poke around the suspension/hub set up, I can't find anything loose or "broken" - all bolts and nuts on the track rod ends, ball-joints, driveshafts, caliper, steering arms, strut etc all tight, no cracks found in anything, spring tight in the shock, shock top mounts tight, no split boots or gaiters, no leaking fluid from anywhere......
In fact the only thing I did find was the big ass 32mm main hub nut wasn't so much loose, but I could get a just under 1/4 turn out of it to really torque it up (by ratchet - not got a torque wrench) After that tho, the banging got worse
Sounds at times like it's driving with a box of rocks in the gearbox, but then at other times it don't. Wind the N/S window down and listen to the sound reverbarate from walls etc, it sounds like your driving along with a shopping trolley tied to the van - there isn't one, I checked Grinding, whirring, creaking, banging, thumping, squeaking - annoying as fuck
But I can't find anything broken And it doesn't drive any differently, as far as steering or suspension feel go.... It's slow as fuck, but has been for ages. YOu have to rev the tits off it to pull away, put your foot flat on the floor it don't pull virtually at all untill it gets over 3,500rpm....
Stumped!
Old Mar 18, 2008 | 06:43 PM
pani_k's Avatar
pani_k
PassionFORD Member
CV joint if a transit even has one?
Old Mar 18, 2008 | 06:45 PM
dojj's Avatar
dojj
Resident Wrestling Legend
the no powr one is a ford ecu reset
the knocking is the driveshaft
Old Mar 18, 2008 | 06:47 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
yip, n/s drive shaft cv joint collapsed prob. Easy to do tho
Old Mar 18, 2008 | 10:21 PM
Thrush's Avatar
Thrush
Thanks
Anyone else of the same, or differnet, opinion?
Old Mar 18, 2008 | 10:37 PM
Lee_R21Turbo's Avatar
Lee_R21Turbo
Sounds very much like my Clio did when it virtually welded the outer offside CV joint together after a full day at Bedford with a split gaitor! lol I thought the car was gonna shake itself to pieces!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
A.t.p
Oct 23, 2015 07:54 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
AJC
Oct 1, 2015 06:47 PM
