wheres best for tappets
am goni get them off matt just on his page the now riting down everything a need and al do it all in the one,r when am servicing it , can u think of anything av missed ?
got tappets,oil filter,oil,belt and tensionor ,fuel filter,anti freeze ,dizzy cap and arm , alt belt , half moon seals, rock cover gasket , and plugs
what plugs would yous advise for a stage 1 2wd saff ?
I would use either 071's or AGPR12PP8, from Matt lewis 01922 692424.
Just make sure to use some sealant UNDER the front cam caps, or it WILL leak from here.
Best to do new seals on cams as well, but use VITON as they are better, but about £9 each, put a bit of sealant around the ends of the half moon seals, and TRIM the gasket as needed to fit in cam cap slots FIRST as they can need a tiny bit taken off to fit in snugly.
foreigneRS
Technical essay Archives
Jul 20, 2025 05:28 PM
Roosie
Aug 13, 2015 07:40 PM
foreigneRS
Jul 20, 2004 11:29 AM
foreigneRS
Jul 20, 2004 11:06 AM
