ABS Sensor help
Old Mar 17, 2008 | 04:50 PM
daviddunlop83's Avatar
daviddunlop83
Default ABS Sensor help
The abs sensor warning light on the dash is tempermental and comes on sometimes. Is there anyway was of testing the sensors?
Thanks
Old Mar 17, 2008 | 06:50 PM
AlexF's Avatar
AlexF
There usually is - what car is it?
But your fault, as its intermitant, sounds like a crud buildup around the sensor/reluctor ring.
Alex
Old Mar 17, 2008 | 06:52 PM
daviddunlop83
sorry is a 3 door sierra cosworth
Old Mar 17, 2008 | 06:55 PM
tajones's Avatar
tajones
I have this on my 4x4 sapphire it seems to come on when you go above 60 mph. But not all the time. Then you turn it off and back on again and the light stays off till you hit this speed again. I've checked all the sensors and there was a couple which were cracked where the bolt goes through. But i've been told it's not this.
Old Mar 17, 2008 | 07:09 PM
ECOS95's Avatar
ECOS95
I had this on my Escort Cos & it was a damaged pickup ring, If you remove the sensor you can see the toothed ring. Mine had some bent / damaged teeth.
Old Mar 17, 2008 | 07:28 PM
To check the abs sensors disconnect them from the connector. Jack the car up and use a multi meter on the to terminals on the sensor. If you spin the wheels you will get a resistance change on the multi meter. The reading should go up and down as the teeth on the pick up ring go past the sensor. If there is no reading well the sensor is fooked.
Old Mar 17, 2008 | 07:40 PM
RC4's Avatar
RC4
Alex
hi alex,the wifes e46 touring abs sensor has gone ,are they easy to replace????,i ordered one ,should be here tomorrow,the guy who tested it doesnt have the time as he,s gone on holiday.
how long will it take and where does it go mate
thanks in advance gary
Old Mar 17, 2008 | 09:03 PM
daviddunlop83
Thanks, do you knwo what sortof resistance i should be looking for?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
