How do i change a rear diff mount????
Old Mar 17, 2008 | 01:27 PM
BA's Avatar
BA
Default How do i change a rear diff mount????
As above, on a 2wd saff cossie, changing from standard mount to Group N, any help/ advice to get the old one off would be much apprieciated!! thanks!!
Old Mar 17, 2008 | 03:53 PM
rinus_2005's Avatar
rinus_2005
Notthing special, first did the 4 bolds to chassis, then the 2 that are connected to the diff. The arb should not give much trouble to work around.
Succes
Old Mar 18, 2008 | 08:23 AM
As said quite easy, just make sure to support car(chassis) on axle stands, AND support the diff weight,with jack/wood or it will jump down.
Plenty of coppaslip on the bolts when putting together.
Old Mar 18, 2008 | 01:38 PM
BA's Avatar
BA
thanks for the replies.... all bolts out now but the mount still wont come off the diff!!
Old Mar 18, 2008 | 07:14 PM
If you have defo taken out the TWO bolts that go through the mount to the diff rear casing, then it is just a bit of differential(metal) corrosion holding it.
You need an IRISH SCREWDRIVER, and whack it not too hard though.
Old Mar 18, 2008 | 11:40 PM
BA's Avatar
BA
thanks, will give that a go....
Old Mar 19, 2008 | 07:02 AM
KSA-Cossie's Avatar
KSA-Cossie
Irish screwdriver.
Oct 9, 2015 07:38 PM
siscossie
Aug 27, 2015 09:27 PM
cameron2
Aug 25, 2015 07:18 AM
track.focus'd
Aug 12, 2015 05:53 PM
xr4x4rs
Aug 6, 2015 09:03 PM
