Efi Sensor
Old Mar 17, 2008 | 10:02 AM
Bakster's Avatar
Bakster
Default Efi Sensor
Hello
What sensor should be here in manifold?? Sensor from efi or from escort mfi?? And how he look??
Old Mar 17, 2008 | 10:10 AM
picky775's Avatar
picky775
should be charge air temp sensor if its goin on a turbo then its a square plug if its goin on a 3i then its a round plug.hope this helps.
Old Apr 3, 2008 | 08:32 AM
Bakster's Avatar
Bakster
So in my efi should be this on the left or on the right
Old Apr 3, 2008 | 09:49 AM
JesseT's Avatar
JesseT
Depends on management you are using. To use a Fiesta turbo management use the right one. To use a XR3i management use the left one. For after market management, use whatever you like. I use the left one with megasquirt, although the sensor is very slow.
Old Apr 3, 2008 | 07:51 PM
Mr.T's Avatar
Mr.T
i think the right one is an GM one?
Old Apr 3, 2008 | 08:34 PM
frsjon's Avatar
frsjon
as jesseT said....n/a left...turbo right...going on fiesta's...xr21/rs turbo..
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
