new clutch for my escos
Old Mar 16, 2008 | 09:50 PM
M16NTE's Avatar
M16NTE
Default new clutch for my escos
guys my monte needs a clutch, wot would be the best 1 for it? its been stage 3 tuned.
and do you think its easy enough to do on the drive or should i put it in the garage to be done?
thanks
Old Mar 17, 2008 | 07:46 AM
GUZZLER's Avatar
GUZZLER
AP organic would be fine (avoid 'cheap' clutch companies)
if your ok with doing gearboxes etc then it shouldn't be too much of a chore to do on the drive, remove the front prop (4 allen bolts) then its the same as a normal rwd box. Will probably need 2 of you to get the box back on, there not light!
Old Mar 17, 2008 | 12:47 PM
krisberic's Avatar
krisberic
If it were me i would go standard again, its the weak link in the drive train and would rather the clutch give up than the box or diffs. Should handle 300bhp any way. I had a stg3 sapph on std clutch and never had any probs.
Old Mar 17, 2008 | 03:06 PM
M16NTE's Avatar
M16NTE
ok cool, thanks!
Old Mar 17, 2008 | 07:07 PM
ECOS95's Avatar
ECOS95
I'm going to go AP Organic when mine is due, had one on my ERST & its was a good feel & didn't slip. I'm planning on running 350BHP.
Old Mar 17, 2008 | 07:37 PM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
Stage 3 is to much power on a std clutch, slips to much when launching.
can only recomend uprated pressureplate and std clutch plate, this will also slip and can take about 400 bhp/500nm (did in my car anyway) and my std gearbox took about 70 full bore launch control launches, and 25k km before 3. gear let go(clutch lasted this long also)
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
gcfcos
59
Oct 6, 2015 05:04 PM
