how much work is it.......
Old Mar 16, 2008 | 08:53 PM
mechanic28's Avatar
mechanic28
Default how much work is it.......
to do a oil pump gasket,sump gasket and the dizzy drive seals etc!(while my head is off?always had a little oil leak and aint sure where it was coming from so while the head is off
Old Mar 16, 2008 | 09:12 PM
Jasesapphy's Avatar
Jasesapphy
if heads off, take the bottom end out and do it on a stand
Old Mar 16, 2008 | 09:26 PM
mechanic28's Avatar
mechanic28
that the easy option then
Old Mar 16, 2008 | 09:36 PM
Jasesapphy's Avatar
Jasesapphy
yep
Old Mar 16, 2008 | 09:41 PM
trevCOSS's Avatar
trevCOSS
is the car 2wd? if so then its a very easy option all things considered, much better than trying to do it in the car
Old Mar 16, 2008 | 09:44 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
If we are talking YB then the oil pump does not have a gasket.. The pick up pipe to oil pump does though....
Old Mar 16, 2008 | 09:48 PM
mechanic28's Avatar
mechanic28
yer fella yb and yes 2wd is it just sealant then?what bout the dizzy drive pulluy i see its got a seal around the pulley but what bout the housing for the pulley?take it the sump has sealant as well?if it a case as taking it out take it u dont have to drop the crossmember etc or get the gearbox out the way to get the engine out?might as well get a 200 block at this rate
JK12
33
Apr 26, 2021 12:09 PM
Rstar_man
143
Jul 20, 2020 11:16 PM
