Pats On Zetec
Old Mar 15, 2008 | 11:54 PM
DIORYY's Avatar
DIORYY
Default Pats On Zetec
I am fitting a 1.8 zetec into a 1.6 zetec can I override the PATS if i fit the 1.8 ECU in?
Old Mar 16, 2008 | 05:14 AM
YES but much simpler to just swap the ignition lock, and key over at same time, then still have your pats.
Old Mar 18, 2008 | 12:47 AM
DIORYY's Avatar
DIORYY
the transponder i have is wired different to the one out of the 1.8 .the 1.8 trany has 4 black wires that split into 2 wires in one plug and 6 wires in another the 1.6 is different again 4 coloured wires from tranny the splits up into 2 multi wire plugs
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
focuspower
Sep 20, 2015 03:51 AM
