car idling high
hi guys managed to get my new engine started and it sounds sweet but it is idling between 1500 and 2000 rpm and doesnt seem to settle at all can this be altered or will it settle in time any help appreciated also would it be wise to give it a test run while this is happening
yes it is bt all standard dont seem to have any air leaks but did notice that the vacum pipes from the tubo and actuator have been blocked with a screw am i right thinking this should go onto the amal valve on top of the intercooler
when you say blocked with a screw, are they not recieveing any form of vacuum control atall now then?
as for idle, on the underside of the inlet, just below where the inlet boost pipe connects to the throttle, you will find a small adjustment screw recessed into the throttle, this controls tickover, will need a reasonable sized screwdriver to twiddle the screw.
cant remember which way raises or lowers the tickover, but atleast you know where to start now
and obviously set the tickover point once the engine is warm
the pipes both go into a tee piece and then blocked so will still be creating vacum just wondered if it would effect it cheers for the advice will give it a go and hopefully be on the road soon
might be worth checking idle control valve on top of inlet manifold (just behind throttle) has a multi plug on it. take valve of check the two rubber seals are ok and clean it with some degreaser.
mines hunting like crazy, definatly a vacum prob cos when you pull pipe of inlet and put finger on hole , it idles perfect!?
rog
Sep 4, 2015 12:10 PM
Zoggon
Aug 10, 2015 10:39 AM
yawiejon
15
Aug 9, 2015 06:36 PM
