Problem With Standard Ford Alarm On Esc Cos
when on holiday and the battery went flat, charged it up and the ford alarm wont stop goin off !!!!! does anyone know anything about the ford alarms and how to stop this ???
cheers
cheers
yer rip it out and throw it in the bin cause thats the best use it has
i hope for your cars sake you have other security otherwise its only time before ya loose it those standard jobbies are fookin pants
cheers
cheers
yep tried that dont make no difference still goes off. might sound silly..... the siren for the alarm is in the rear quater panel. the boot now does work at all cant open by the key or the button ??? is the a safety thing stoping you from discounting the siren?????
cheers
cheers
Is the red light on next to the clock?. When I got my new alarm fitted i fucked the blackjax and set the whole lot off. In the panick I activated the std alarm by turning the key in the door as Doug says. PLay around with this until the red light goes off, you should then be back to normal.
Paul
Paul
kosienutter
31
Aug 22, 2015 09:55 AM
