plumbing oil swirl pot
no but pic on ebay shows it fitted to a s2. but its not clear enough to see were they go. theres three 12mm pipes and a smaller pipe on the top and 1 out the bottom which i presume is the return to the crankcase
got me 1 of those the other day. the bottom 1 goes down in to crankcase,the 1 on the left goes on left side of rocker cover, 1 on right goes to right hand side of rocker cover. 1 on left goes down in to metering unit and the small 1 return round in to inlet plenum. hope that helps mate.
If its venting into the inlet make sure you fit a one way valve on the vaccum hose otherwise everytime the manifold goes positive pressure (on boost) it will be pressurising the sump aswell via the breather.
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
