i'm using the standard brakes all round with no abs just using the rear compensators and the car is fine/balanced when braking very heavily- alots more responsive than with the abs for sure
When i did my rear disc conversion i removed the abs at the same time!! there was loads of air in the system and it was a piece of piss to bleed it all after!!!
as for how i just made up pipes from the cylinder to the T's on each inner wing and binned the abs completely
can make up more pipes in anybody wants, i can post as a reel then you just shape how you see fit and bolt into the fixings either end
easiest way by far, spend weeks trying to get braided made but no joy
