random water?
Old Mar 13, 2008 | 06:23 PM
RS LOZWORTH's Avatar
RS LOZWORTH
Default random water?
my saff keeps randomly dumping small amounts of water on my garge floor after ive used it, it dosent do it all the time just occasionally but i cant find any holes or it dosent seem to be loosing water, any ideas? and it aint rain
Old Mar 13, 2008 | 06:46 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
you said its not rain?so does it smell of antifreeze?,if not its probably water from the chassis rails or other water trap.
Old Mar 13, 2008 | 07:23 PM
RS LOZWORTH
yer def not rain, i will c wot it smells of, but the puddle is directly under the engine
Old Mar 13, 2008 | 07:24 PM
rssteve's Avatar
rssteve
air con?
Old Mar 13, 2008 | 07:25 PM
RS LOZWORTH
Originally Posted by rssteve
air con?
nope
Spiky's Avatar
Spiky
no rusty marks on the engine?
under which part of the engine? front ? rear? which side??
Old Mar 13, 2008 | 07:27 PM
RS LOZWORTH
id say more to the fron of the block and under the sump ish.....
my worst fear is that the block is cracking and when the car is warm the crack is opening and when its cold ie. when i try to find the leak there is nothing, i hope it is not this
Old Mar 13, 2008 | 07:29 PM
Spiky's Avatar
Spiky
water pump, look for some crystals below it,
is it 4wd? if so check the small samco between the water pump and thermostat housing,
thermosta housing
check at the rear of the block ex side, goes ofter there, will leave a rusty look to the block
RS LOZWORTH
its a 2wd
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
