mtx 75 gearbox in rst
surely if you were to fit the focus rs box it would keep costs down a bit. Surely it just involves fabricating two mounts,having driveshafts made and fitting/modding gear selector off a mk5/6 escort?
The Ł1600 quoted by oddkiddcreations covers.
S1 rebuilt rollbar setup
Rose jointed Solid tie bars
Solid tie bar clamps
A rebuilt RS2k MTX75 box with upgrades if wanted.
1x Engine mount lowering the engine
2x Gearbox mounts with or without Vibretechnic mounts
2x Custom shafts
2x Inner CV Joints
2x Outer CV Joints
Gear linkage Quick shift style
AP custom made Clutch
Mods to the chassis i.e Welding painting etc.
Fitting!
2x Custom shafts
2x Inner CV Joints
2x Outer CV Joints
Fitting!
Does anyone know if fiesta rs hubs are same spline as escort rs ones....
Obviosuly the gearbox end is but not sure if the hub would be the same.....
Wul where did you get your shafts from then in the end.
I was promised the earth by Jano on a kit for this conversion! Bloke was a complete messer!
Job isnt that hard to do if your are half decent with a spanner.
I have my mounts now done and had 20 sets cnc cut at the same time ready to be welded up. I can do ones that will drop the box about 40mm making life much easier on the linkage conversion or ones that keep the standard engine position. These will only work with a S1 suspension and mount set up tho as I have converted my car to run this.
i was quoted 250 for shafts and mounts as a diy kit but not saying this is the official figure tho as i noticed he quoted another price for same stuff of 500 but i know that was a later development of the kit.
TBH I have just been too busy to even look at them. I am sending some stuff over to Christian for him to finish off and try on the car. I need time to get out and buy some box section to finish a set off.
If I said Ł100 how would that sound? You will need to speak to me though as this is based on a S1 susupension setup and there are two options for the mounts depending if you want to drop the engine or not.
