My SECS Monitor shows my MAP -0.9 when the engines off?
Old Jan 31, 2004 | 03:51 AM
Default My SECS Monitor shows my MAP -0.9 when the engines off?
As title - is this normal? Anyone else with a secs show different? Bad earth to map sensor?
I also have a SPA boost gauge and the SECS guage are off by like 3.5-4 psi at full boost (like 26 psi).
Anyone else have a difference in boost gauge to ecu monitor?
Old Jan 31, 2004 | 09:42 AM
the original's Avatar
the original
not normal but don't know why. mine reads zero with engine off
Old Jan 31, 2004 | 01:05 PM
alan rainbow's Avatar
alan rainbow
mine reads -0.8 what map sensor are you running 3bar ect
Old Jan 31, 2004 | 02:11 PM
wighthot's Avatar
wighthot
Mine reads -0.8 as well, it's running a 3bar
Old Jan 31, 2004 | 05:59 PM
Yeah, I have a 3 bar also. Does your boost gauge show a higher boost than the ecu monitor too?
Old Jan 31, 2004 | 06:10 PM
alan rainbow
not to sure on the boost gauge but iam on a 3 bar as well it seems to be the norm then try secs they might be able to tell you the reason for this
Old Feb 9, 2004 | 07:06 PM
Damo V's Avatar
Damo V
Something to do with air pressure, dependent on height above sea level IIRC???
Old Feb 9, 2004 | 08:24 PM
My SPA boost gauge reads 0.0, so don't think it's that.
Old Feb 10, 2004 | 11:00 AM
Damo V's Avatar
Damo V
yeah but does the spa gauge read from the MAP sensor??
Old Feb 10, 2004 | 04:28 PM
Dave Henshall's Avatar
Dave Henshall
exactly.
manifold ABSOLUTE pressure - not gauge pressure, a so a gauge will read 0 when the absolute pressure may be slightly above or below 1 bar absolute at different atmospheric conditions
Old Feb 10, 2004 | 04:31 PM
Damo V's Avatar
Damo V
:takes a bow:
see I do know some things pmsl.....
Old Feb 10, 2004 | 05:57 PM
Blakeya's Avatar
Blakeya
You can forecast the weather with a SECS too
Andy
SmudgerByName
52
Jul 28, 2016 06:14 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
Red_bull
Aug 25, 2015 06:27 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
Bailes1992
Aug 16, 2015 07:14 PM
