4x4 Bonnet Vent Brass Inserts
Old Mar 10, 2008 | 07:09 PM
Simmo's Avatar
Simmo
Default 4x4 Bonnet Vent Brass Inserts
Does anyone know if you can get new inserts for the 4x4 Bonnet Vents?... the brass threaded jobbies that fit in the plastic pegs...
Old Mar 12, 2008 | 05:07 AM
stevecossy's Avatar
stevecossy
I dont think ya will get em from ford, maybe have to find a company that does that sort of thing or 1 that can just make some for ya buddy.
Good luck regards steve
Old Mar 12, 2008 | 05:46 AM
I would be amazed if these were ever available seperately from ford at any time.
Old Mar 12, 2008 | 07:51 AM
RS Juto's Avatar
RS Juto
I just took a small nut and ground off the flats to make it round and then epoxy resin'ed then in. Then I used stainless capheads to hold my vents and stainless plates in place.
Old Mar 12, 2008 | 04:30 PM
Simmo's Avatar
Simmo
tabetha... It appears not, spoke to my parts man today at Ford and the only items available seperately are vents (£90each!!!), bolts and washers... no ferrule thingies!!!
cossie1000... That sounds like a good plan, never thought of that!!!
Old Mar 12, 2008 | 06:26 PM
I have some s/h ones but six captive nuts are missing.
I was going to fix these with JB weld over the nut that I inserted DOWN the hole first, so it is totally covered apart from the hole for the screw, I drilled the holes deeper for this, but then luckily found two new ones for £75, so using them now.
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
cossie330
Sep 27, 2015 04:13 PM
