Rear Anti Roll bar sizes
Old Mar 10, 2008 | 05:54 PM
robrs2's Avatar
robrs2
Default Rear Anti Roll bar sizes
Just after the sizes for rear anti roll bars. as fitted to the XR4x4, 2wd and 4wd Cossie and the Escort cossie.
I think the 4x4 Saff Cossie is 18mm ?
The Granada Cossie is 18mm as i have one. Also i have a 20.5 mm one is this the biggest there is?
Rob
Old Mar 10, 2008 | 07:07 PM
XR4X4 12mm or 14mm, depending on year
3 door cossie 14mm
2wd sapphy 16mm
4wd sapphy 18mm
escort cossie 22mm
scorpio cossie 21mm
Old Mar 10, 2008 | 08:58 PM
robrs2's Avatar
robrs2
That will do thanks
Old Mar 24, 2009 | 04:10 PM
Mike1's Avatar
Mike1
Anyone on here tried the 4x4 version on a 2wd Sapphire? It looks quite a bit stiffer without resorting to the massively stiffer Escort Cosworth one which I think might tax the mounts too much and upset the balance perhaps.
Going to see what effect the adjustable beam ( next month fitting ) has first but then thinking of what to try after that.....
Old Mar 26, 2009 | 06:48 PM
Mike1's Avatar
Mike1
No-one at all running a 4x4 version on the back of a 2wd?
Old Mar 26, 2009 | 08:31 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
I have a 4x4 rear roll bar on my 2wd saph
Steve
Old Mar 26, 2009 | 10:38 PM
robrs2's Avatar
robrs2
I have a 4x4 one on my 3 door
Old Mar 27, 2009 | 09:00 AM
Mike1's Avatar
Mike1
Steve
Did you notice much of a difference Steve?
Is it just the bar or do you need different drop links on the ends?
It's supposedly about 1.5 times stiffer I believe?
Old Mar 27, 2009 | 02:07 PM
dazzle740's Avatar
dazzle740
i also run a 4x4 one on my 2wd yes they are stiffer and no nothing else needed same drop links
oh sorry you will need the apropiate bushes for the beam you fit
Old Mar 27, 2009 | 02:08 PM
Moonstone Steve.
Ask me in a months time m8, its been off the road since i fitted it having a resto, i did fit new links aswell but they were only 2wd links.
Steve
Old Mar 27, 2009 | 02:16 PM
dazzle740's Avatar
dazzle740
the drop links are all the same between the cossies , but you can get the bushes that go in the drop links seperate from the bars if needed.
Old Mar 27, 2009 | 03:04 PM
Mike1's Avatar
Mike1
Steve
Ah cheers Steve, I would be interested to hear what you think of it when yours is up and running.
I'm sure I read that the 4x4 one is approx 1.5 times stiffer in roll resistance than the standard 2wd one.
Obviously the Escort Cosworth one is stiffer still but at 3.5 times stiffer than the standard 2wd one and without there being an easy upgrade for the front ARB, my thinking is that there would be too much of a roll disparity between the front and rear axis perhaps. This seems to be borne out by people saying they become a bit too twitchy on the rear in 2wd form when running an Escort Cos rear bar.
I'm also not sure how much extra stress it would put into the mounts with the Escort one compared to the Sapphire 4x4 one.
Old Mar 27, 2009 | 08:09 PM
nicksaph's Avatar
nicksaph
i think the bushes are bonded in mate so it is a complete link , and i think they are about £8 each mate if i remember right.
Old Mar 28, 2009 | 03:28 AM
dazzle740's Avatar
dazzle740
I'm only going by the fact that i got four new bushes from my local ford dealer without the link bar.
Old Mar 28, 2009 | 12:05 PM
Mike1's Avatar
Mike1
So no-one has tried the 4x4 rear bar on a Sapphire apart from Steve?
Seems to be a few who've tried the much thicker Escort one .....and then complained it has been a bit too skittish perhaps.
Old Mar 28, 2009 | 09:59 PM
nicksaph's Avatar
nicksaph
sorry mate, bit of a dyslexic moment there mate, thought i read "can you get bushes" instead of "you can get bushes"
Old Mar 29, 2009 | 02:53 AM
dazzle740's Avatar
dazzle740
As i said above i have got a 4x4 one on the rear of my 2wd noticed a hugh improvement a mate of mine with a 4x4 used the ecose one and said the rear became very nervous
Old Mar 30, 2009 | 07:24 AM
Mike1's Avatar
Mike1
Ah cheers Dazzle - somehow missed your post.
Seems to bear out what I was hearing, maybe the Escort Cosworth rear bar is just a bit too much for a non-track car on bumpy, sometimes wet roads.
I'll hunt down a 4x4 version for mine
Old Mar 30, 2009 | 11:04 AM
dojj's Avatar
dojj
Resident Wrestling Legend
i'm another one, even with really soft suspension and standard bushes, the back end just doens't have enough give in it and it gives very easy tail out action under the slightest of provocation when the roads aren't 100% dry
Old Mar 31, 2009 | 06:22 PM
Mike1's Avatar
Mike1
Cheers Dojj - that echoes what I read from Tony @ Turbosystems
Old Mar 31, 2009 | 07:54 PM
dojj's Avatar
dojj
rainbird also has the same onion on the matter, but i'm not sure how he goes about sorting it, other than putting a softer arb on it
Old Mar 31, 2009 | 08:23 PM
Mike1's Avatar
Mike1
Spring?
He certainly knows his onions.......
Old Apr 15, 2009 | 07:33 PM
Mike1's Avatar
Mike1
Hi there anyone who has replaced their rear ARB links recently...
Just got hold of a 4x4 rear bar with the links on. The original coating is all peeling off the ARB so I plan to have it powdercoated and fit all new links and bushes. Quick question though....how did Ford fasten the links to the bar originally? Are they crimped on somehow? ( it's all a bit rusty so I can't see exactly )
Old Apr 15, 2009 | 08:23 PM
groomers's Avatar
groomers
just pull over with a pair of pipe grips bud
Old Apr 15, 2009 | 09:42 PM
dojj's Avatar
dojj
if you are struggling to put them on use a wind in cramp lke they do with woodowrk stuff with a socket over the end to stop it bottoming out
just squirt some fairy liquid on the rubber to help ease it over as well
Old Apr 16, 2009 | 12:43 PM
Mike1's Avatar
Mike1
Cheers chaps, it's apparent now I've got one off that they are just a push fit!
Old Apr 16, 2009 | 01:03 PM
dojj's Avatar
dojj
yes mate, but you need to be built like the terminator to get one on using just your hands
TrevCos
Aug 17, 2015 09:08 PM
track.focus'd
Aug 12, 2015 05:53 PM
Bosch
Aug 4, 2015 05:14 PM
Graceland
Jul 31, 2015 10:34 AM
