xr4 coilovers and wheels???
Old Mar 10, 2008 | 03:58 PM
paul302289's Avatar
paul302289
Default xr4 coilovers and wheels???
can anyone help? i've just fitted gaz coilovers to my xr4i and am having a bit of trouble gtting wheels to fit. i've got some 17 inch wolfrace but they rub on the front shock, does anyone know the best size wheels that will fit, aftermarket or off of another ford, done a fortune so far so would like the cost kept down for now and get something tasty in the future?
Old Mar 10, 2008 | 04:04 PM
STUCOS's Avatar
STUCOS
Paul,am i guessing tyre/wheel rubs on spring seat,if so i had same problem with my 3dr on 17 in wheels,raise spring hight or run shorter springs
cheeRS stu
Old Mar 10, 2008 | 05:59 PM
paul302289's Avatar
paul302289
the rim is actually rubbing on the shock. that is without a tyre on the wheel. i dont think i can raise the spring that much to clear the tyre without it looking like a paris dakar racecar. also the rim is too wide to space the wheel out, if i did it would look like carlos fandago super wide wheels. i'll give gaz a call to see if i can fit a sorter spring but i doubt it as they will need to be stiffer so the ride will suffer, appparently they will be harsh as they are. cheers, Paul
jessie_rs
62
Aug 6, 2019 09:27 PM
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
yorkie92
Sep 6, 2015 05:34 PM
Adam Graham
Sep 6, 2015 06:04 AM
