seirra 4x4 rear diff
Old Mar 10, 2008 | 12:38 PM
ant cozzie's Avatar
ant cozzie
Default seirra 4x4 rear diff
my diff has gone on my escort cosworth and ive got an old D reg seirra 4x4, are they the same diff?
Old Mar 10, 2008 | 01:03 PM
Dave Henshall's Avatar
Dave Henshall
different slip settings - but would phisically fit
Old Mar 10, 2008 | 01:09 PM
Some are 7" some are 7 1/2" but can't remember which way round!!
But each can be fitted to each other reasy enough.
Old Mar 10, 2008 | 01:20 PM
cozmeister's Avatar
cozmeister
More boost Igor!
http://forum.fordsierraclub.co.uk/vi...276&hilit=diff
http://martyn.sillyproject.com/backup/diffs/diffs.htm
These may help.
Old Mar 10, 2008 | 02:01 PM
rog's Avatar
rog
What about the ratios though, they are diddferent are they not????
What would this do???
Old Mar 10, 2008 | 02:37 PM
Kelv's Avatar
Kelv
Almost there!
i was going to say it would be ideal to check that the sierra diff isnt 3.9 instead of the escos 3.62.
Old Mar 10, 2008 | 03:34 PM
ant cozzie's Avatar
ant cozzie
how can i find out wot ratio it is?
Old Mar 10, 2008 | 07:37 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Mark the input shaft, mark the output shafts. Turn the input 3.9 times, and the outputs shafts should only rotate once, should be able to see the differance between 3.6 turns of the input and 3.9. The messy way is to take the rear cover off and count the teeth on the crownwheel and count the teeth on the pinion, divide the crownwheel number by the pinion number and that should give you your ratio
Old Dec 2, 2010 | 12:18 PM
seventhheaven's Avatar
seventhheaven
In Development
Hi,
A friendly man at the local ford dealer let me use his microfiche machine and I've managed to get all the part numbers, FINIS numbers, exploded diagrams etc for Sierra, Granada and Scorpios. I'm putting together everything I've found at www.super7thheaven.co.uk
Hope that helps - It's a work in progress
Old Dec 2, 2010 | 01:20 PM
grcossie's Avatar
grcossie
Sierra 4x4 and Escort have the same diff, whit the same ratio. Only 2wd have 7,5" and 3.64
3.9 is not oe in any Cosworth
FlashRS
Sep 14, 2015 12:36 PM
3drRich
Sep 13, 2015 07:32 PM
mint_s2
Sep 2, 2015 08:58 AM
xr4x4rs
Aug 6, 2015 09:03 PM
