What do people reckon to head spacers????
Old Oct 19, 2004 | 03:14 PM
davidnormanuk's Avatar
davidnormanuk
Default What do people reckon to head spacers????
Found a place that do head spacers for the RST. He can go up to 3mm for heads that have been skimmed too much and to lower the compression to run lower boost.
Has anyone used these spacers?
Dave
Old Oct 19, 2004 | 05:03 PM
james_birch's Avatar
james_birch
never heard of them!...but am seriously intrested
Old Oct 19, 2004 | 05:06 PM
A16XSO's Avatar
A16XSO
ill be intressed in some, but never heard of them
Old Oct 19, 2004 | 05:19 PM
KSA-Cossie's Avatar
KSA-Cossie
Should that not be higher boost m8?!
Old Oct 19, 2004 | 05:53 PM
davidnormanuk
Should run higher boost. Doh.
website is: www.ferriday.co.uk
Sounds like he knows his stuff.
Dave
Old Oct 20, 2004 | 02:45 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
that will need 2 head gagkets which will last 2 miles if your lucky! it's basically like a de-compression plate as can be used on a ZVH.....
Old Oct 20, 2004 | 08:46 AM
davidnormanuk
He says you don't need 2 gaskets. You use wellseal on the block side and then use the gasket as normal on the head side. He says he hasn't had any problems so far with them so fingers x'd.
Its got to be worth a go.
Dave
Old Oct 20, 2004 | 10:07 AM
james_birch
Dave
worth a go if you have a spare engine!...
Old Oct 20, 2004 | 11:13 AM
IANS2RST's Avatar
IANS2RST
about as reliable as a bleed valve, hope your good at changing head gaskets
Old Oct 20, 2004 | 11:30 AM
mattbibs's Avatar
mattbibs
i agree - id keep well away from that sort of thing.
if you want low comp then get low comp pistons!
Old Oct 20, 2004 | 02:50 PM
davidnormanuk
The guy says people who race with them on havn't had any problems.
Got a spare engine so its worth a go.
Dave
Old Oct 20, 2004 | 07:46 PM
NEO™®©'s Avatar
NEO™®©
theyre crap just a cheap way of lowerin the compression but can only hold 8-10 psi max not worth shit keep well away if u wanna bodge it like that skim ya pistons lol
Old Oct 21, 2004 | 12:06 AM
vroooom ptssssh
It Wasnt Me!
a pimp would sell u a fat bird who goes like fuck even tho she cant touch her hands behind her back!! be careful mate, i'd seriously reconsider!
jessie_rs
62
Aug 6, 2019 09:27 PM
dombanks
Sep 21, 2015 08:38 PM
kevin36
Sep 8, 2015 12:23 PM
hopper350
Sep 4, 2015 12:53 AM
