prop fouling on exhaust ...HELP...
Old Mar 9, 2008 | 06:56 PM
cossie.con's Avatar
cossie.con
Talking prop fouling on exhaust ...HELP...
Hi Guys Just Fitted My Engine Into My Car And When I Connected The Front Prop I Noticed The Large Knuckle Type Joint At The Front Catches On The Exhaust Which Is Bolted Up And Is On Its Rubbers Correctly Any Help Very Much Appreciated.
Old Mar 9, 2008 | 07:06 PM
THE RADMAN's Avatar
THE RADMAN
they are a very tight fit you just need to slacken off the exhaust/turbo bolts and the front exhaust clamp and tweek it all to clear
Old Mar 10, 2008 | 01:22 PM
G1EN's Avatar
G1EN
I had this too a short while back and it only stopped after the turbo bolts were mega tighted as they kept working slightly loose.
Has been fine since...
Poly exhuast hanger busges help too.
Old Mar 10, 2008 | 04:45 PM
cossie.con's Avatar
cossie.con
thanks for the replys guys will have a go at it soon
tankybaby66
Feb 6, 2016 02:24 PM
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Russ Payne
Sep 25, 2015 08:29 PM
