saphire missfire help please!!!!!
Old Mar 8, 2008 | 04:31 PM
cos4x4cos's Avatar
cos4x4cos
Default saphire missfire help please!!!!!
My sapphire has developed a missfire, it is okay on idle, when you rev it or drive it it starts to missfire!!!!!!! when on boost it goes away. Any ideas please...................... I have changed the crank pulley as one of the lugs was damaged. plugs and rotor cap. fault still there.
Old Mar 10, 2008 | 11:56 PM
NEILNATO's Avatar
NEILNATO
SCOOBY DOOBY DON'T!!!
Sounds like a possible dribbling injector, Get them checked out. I.E when on atmospheric running it is running too rich hence the miss-fire, then when on boost it clears up due to the volume of air being forced into the cylinders. Also you didnt state what injectors you are running. If you are using injectors that are to big for your engine setup then you can run the risk of bore wash which will leed to a costly rebuild.
Old Mar 11, 2008 | 01:37 PM
Look for air leaks then, get your CO set.
fish6634
Ford KA
Aug 2, 2015 01:02 PM
ginger1979
Jul 31, 2015 09:56 PM
FletchCossie
Jul 19, 2004 08:17 PM
AlexD
Feb 26, 2004 08:59 AM
