rs500 inlet manifold
Old Mar 7, 2008 | 09:18 PM
cozzy jeff's Avatar
cozzy jeff
Default rs500 inlet manifold
i bought an rs 500 inlet manifold and when it arrived i noticed the pipe between the throttle body and elbow was missing and the holes had bin filled with alloy bungs will i have to use an aftermarket ecu to control the idle speed
Old Mar 8, 2008 | 07:28 AM
NO you won't but you must of course have a way of getting air around the throttle plate.
Saying that it is not the end of the world, some people run without idle speed control, without any problems, just have to be a bit more easy on throttle when cold that's all coming to a stop as it will try and stall until warm.
You could use something like a mody iscv, and make a plate up for it to sit on so you have an air IN/OUT then just route either side of the throttle plate.
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
caprixpack
Sep 25, 2015 07:53 PM
