rs turbo trouble
Old Mar 7, 2008 | 03:49 PM
cossie362's Avatar
cossie362
Default rs turbo trouble
hi peeps having trouble with my h plate rs turbo
when i start the car it seems to start then cut out again almost immediatley
the car will not idle if i press the accelarator a little and hold the car just over a 1000rpm
it runs but as soon as im off the accelarator it splutters and then cuts out
just had an mot on it to any ideas??
Old Mar 7, 2008 | 04:14 PM
velocity's Avatar
velocity
more than likely you have an air leak.in other words there is air gettin in after the the fuel metering valve plate which you can see when you remove the air filter.
check all the turbo hoses for loose clips and any air pipes that are on the inlet manafold.make sure the oil filler cap is a good fit, if you have a dump valve fitted then remove it and blank the hole just in case this is the problem.
see how you get on
Old Mar 8, 2008 | 11:04 PM
crashley's Avatar
crashley
Default rs
i know it sounds stupid mine done the same thing it didnt have enough petrol in it
Old Apr 7, 2008 | 10:42 PM
Jucks's Avatar
Jucks
Arrow
did u get it sorted after mate.. i m having a simlar prob too.. would you mind posting a follow up here if you have any sugestions.. thanks.. https://passionford.com/forum/showthread.php?p=3213043
Old Apr 8, 2008 | 10:00 AM
diesel's Avatar
diesel
i would say air leak aswell see if the hose on the meter unit is on tidy the breather comming from the rocker
i had a problem like that i was changing the bleed valve to a standard amel valve and accidenly pulled the breather off it was stumped for hours
Old Apr 8, 2008 | 10:03 AM
diesel's Avatar
diesel
stupid to ask have you tightent the air fillter up when i rebuilt my car i forgot one's
Old Apr 8, 2008 | 11:14 AM
IANS2RST's Avatar
IANS2RST
did the mot station alter the fueling to get it throught the emmisions?
try adjusting the mixture screw(3mm allen key behind the air filter on metering head) 1/2 turn clockwise
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
fordjames
Ford Focus Diesel
Sep 3, 2015 10:20 PM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
