will a alloy radiator keep my car cooler ?
hve a full width airtec intercooler with twin fans at the mo wit standard rad,it runs round the town rather hot, just under 3/4 on temp gauge9thats with twin fans on) the standard radiator does not sit flush with the cooler but i herd that alloy ones bolt onto th cooler ? will this cool the rad down more ?
thnks sean
thnks sean
i have exactly the same problem mate, same airtec cooler. im thinking of getting the airtec rad ready for summer. just out of interest how is yours set up fan wise.
mine is fans, cooler then rad.
ben.
ben.
yes and no,it will keep your temps cooler but once its warm it will take longer to disperse the heat
if youve probs with temps then an alloy rad is not the solution,look elsewhere in the coolin system
mines is exact same mate,tryed so many times but failed to fit the fans in the middle to cool th rad down
Last year I was running a Pace ali rad, my cooling was close to the limit. But wear and tear on the rad meant I had to replace it.
This year I have a new GRS ali rad and the cooling is superb.
Conclusion - a fresh, clean uncontaminated rad will improve the cooling no end.
Also if you remove the water cooling from the turbo it means that a lot of heat will be passed into the oil system.
S.
S.
S.
S.
could this increase charge temps too?
The S1 was designed to run without water cooling to the turbo, while the S2 was designed with it.
I haven't seen clear evidence of an Alloy rad cooling better than a new standard one.
Simon - the copper may conduct better, but what about the brazing
anyway, as i said before - it will improve things, simply because your existing rad will be shitted up nicely.
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
rsstav
Aug 11, 2015 04:22 AM
