anyone lowered a ka?
Old Mar 4, 2008 | 09:23 PM
ScORTED's Avatar
ScORTED
Project Money Pit
Arrow anyone lowered a ka?
just after any potential pit falls etc, my lass's ka failed its mot on a cracked spring so we got some rs eibach springs from pumaspeed and i'm going to fit them tomorrow.
if anyone has a link to a guide or as i say some general advice? its a 2004 sport ka
Old Mar 5, 2008 | 06:34 AM
They should be pretty straight forward to do. It should have anti roll bar links on the front. Sometimes these are a pain to get off. They have an allen key hole for an allen key in the top of the link rod where they go though the shocker. It will no doubt wear off. I normally get a good set of mole grips and clap them on the back of the link rod then undo the nut. The rest of it is easy.
Old Mar 5, 2008 | 10:58 AM
ScORTED's Avatar
ScORTED
Project Money Pit
thanks, i'm off for a bash at it now, i've mainly worked on escorts etc and the setup looks similar hopefully i won't have any problems
Old Mar 5, 2008 | 11:36 AM
Well fingers crossed mate and good luck.
Old Mar 5, 2008 | 12:35 PM
vibrating_cake's Avatar
vibrating_cake
easiest car to fit springs ive ever done
rears can do within the hour (to get the spring off just yank the bumpstop over the top of the shock dont fanny around with removing the circlips)
rest is streightforward so are the fronts.
oh yea, slacken ALL bolts u need to remove before removing everything!!!
or ull see yourself bolting things back up to slacken bolts later on
Old Mar 5, 2008 | 08:40 PM
ScORTED's Avatar
ScORTED
Project Money Pit
yeah did the rears... four times... only took a few hours.
had to go back and change the springs then forgot to fit the dust boots, then had to make a bush to stop the spring cup moving too far and dislocating the springs with the car jacked up.
i'm sure the fronts won't cause me any bother
cheers
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
IainRS1700T
Sep 25, 2015 06:44 AM
roomey
Sep 19, 2015 08:40 AM
