Question for all RST owners Re:Cylinder heads (example pics)
Old Oct 18, 2004 | 07:34 PM
GraphiteGray's Avatar
GraphiteGray
Default Question for all RST owners Re:Cylinder heads (example pics)
Hi all
Has anyone got a cylinder head on their RST that has 'cross hatching' ( like a raised grid pattern #) across the front between the spark plug holes, along the back of it where the numbers are, and inside the between the rockers and valve springs??
If you have could you please tell me what year your RST is?
Any help at all would be greatly appreciated, no really!
Thanks so far for all the help youve given me so far with the pics, youve really helped me out where others just muck me about!
Gray
Old Oct 18, 2004 | 07:45 PM
Lee @ Fusion's Avatar
Lee @ Fusion
Sounds like a very late one ,
you see a lot of FRST heads and XR2i heads like this ,
I have had loads of RST's none newer than a 89 and they have all had the plain ones .
Old Oct 18, 2004 | 07:52 PM
s1rscustom's Avatar
s1rscustom
series 1's have them on aswell
Old Oct 18, 2004 | 08:05 PM
GraphiteGray
Has yours got the pattern on it like mine?
Without the head on me ( at Burtons ) i cant realy give much info, apart from it had round exhaust ports and was unleaded
If i can identify what head it is ill be able to get a another one
Gray
Old Oct 18, 2004 | 08:07 PM
s1rscustom's Avatar
s1rscustom
yeah had couple os s1 heads and had the squares on but series 2 sisnt certain they s1's suppose be better than s2 but somebody else must know about them
Old Oct 18, 2004 | 09:38 PM
GraphiteGray
Got some example pictures i found, see top of post
Thanks
Gray
Old Oct 18, 2004 | 10:05 PM
DazC's Avatar
DazC
Default Re: Question for all RST owners Re:Cylinder heads (example p
Originally Posted by GraphiteGray
That is a late EFI head. Either Fiesta RST, XR2i or last of the Mk4 XR3i....
Old Oct 18, 2004 | 10:13 PM
GraphiteGray
Its off a Fiesta RST, i used these pictures to show the grid pattern that mine has
Billy_RS
16
Oct 11, 2025 09:41 PM
Chas
Sep 21, 2015 08:57 PM
borboyous
Aug 22, 2015 11:17 AM
A.t.p
Aug 15, 2015 11:37 AM
dlwarrior
Aug 5, 2015 10:19 AM
