efi turbo...splutter on boost???
Old Mar 2, 2008 | 05:39 PM
stbaz's Avatar
stbaz
Unhappy efi turbo...splutter on boost???
fiesta turbo efi engine in my mates escort....... running fine starts fine etc but when its boosting it coughs and splutters and holds back where as on light throttle if you build the power up very slowly it will boost ALOT better. any ideas guys? help appreciated
Old Mar 2, 2008 | 05:44 PM
Phil2002's Avatar
Phil2002
turn the boost down may be running to much boost for what the ecu is chipped for. check plug gaps you may be blowing out the spark.
Old Mar 2, 2008 | 05:48 PM
stbaz's Avatar
stbaz
Unhappy
ive turned the boost down already but it still seems the same. have changed the injectors too
Old Mar 2, 2008 | 06:07 PM
Phil2002's Avatar
Phil2002
I'd check coil pack, plugs and leads next i think sounds to me like a weak spark.
Old Mar 2, 2008 | 06:08 PM
Ollie MK5 Turbo's Avatar
Ollie MK5 Turbo
Fuel Pump?
Old Mar 2, 2008 | 06:13 PM
Mr.T's Avatar
Mr.T
What he says ^^
Old Mar 2, 2008 | 06:46 PM
stbaz's Avatar
stbaz
Unhappy
Will Mfi Xr3i Fuel Pump Do The Job As I Have Few Spare Lying About??
Old Mar 2, 2008 | 09:29 PM
rsdan123's Avatar
rsdan123
what injectors/chip are you running?
Old Mar 2, 2008 | 11:02 PM
NEWTON's Avatar
NEWTON
no cos the fiesta one is in the tank
Old Mar 3, 2008 | 10:06 AM
cabbykarl's Avatar
cabbykarl
Says he's put it in an Escort, so if MK4 external pump but 5> internal.. MFi fuel pump runs higher pressure than EFI so i'm sure it'll be ok unless the pumps duff of course...
Interested to know the outcome though as mine's doing something a bit similar.
Old Mar 3, 2008 | 07:36 PM
stbaz's Avatar
stbaz
its on standard injectors. been told the ecu was chipped when the car was bought but not sure. the guy said its got a 190 chip. as i say though i cant be sure if it does.
Old Mar 3, 2008 | 07:38 PM
Mr.T's Avatar
Mr.T
Don't you need beiges for 190?Or am i wrong on this?
Old Mar 3, 2008 | 07:49 PM
stbaz's Avatar
stbaz
i dont know. this is why i have posted this thread. my own car is mfi, never really had much to do with efi
Old Mar 3, 2008 | 07:58 PM
rst in breaking's Avatar
rst in breaking
if u have a 195 chip then as far as im aware u should be running bieges and commonly t3?
rst in breaking
have you had the car running ok since owned?
Old Mar 3, 2008 | 08:00 PM
stbaz's Avatar
stbaz
its defo got t3 on it yeah. mmmmm looks like need standard chip then as my mate is happy with standard power. when the car was bought it was a bit mix matched i think. think the running problem is why the guy sold it.
Old Mar 3, 2008 | 08:01 PM
stbaz's Avatar
stbaz
no its been like that since he picked it up two weeks ago
Old Mar 3, 2008 | 08:12 PM
rst in breaking
the chip just unplugs to run standard set up, but then you will need a t2 and blue injectors for it to match and fuell correctly
Old Mar 3, 2008 | 08:47 PM
stbaz's Avatar
stbaz
so theres is no need to replace with a standard chip?? just unplug the upgraded one?
Old Mar 3, 2008 | 09:03 PM
rst in breaking
yes, but your engine will fuel wrong due to the t3 conversion
Old Mar 9, 2008 | 06:36 PM
stbaz's Avatar
stbaz
cured....thanks for your help guys
Old Mar 9, 2008 | 06:43 PM
cabbykarl's Avatar
cabbykarl
How? If u don't mind my asking m8
Old Mar 9, 2008 | 06:53 PM
Mr.T's Avatar
Mr.T
yeah would like to know that to
Old Mar 9, 2008 | 09:23 PM
stbaz's Avatar
stbaz
IT HAD BOSCH SUPER4 PLUGS IN IT. TOOK THEM OUT AND PUT NGKs IN IT......WE PUT THE CHIP BACK IN IT....STILL GOT A T3 ON IT AND THE ORIGINAL BLUE INJECTOR AND THE THING FLIES!!!! WOO HOO.....MAYBE NOW IL GET PEASE TO GET MY OWN PROJECTS DONE HAHAHAHAHAHA
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
dms04
Sep 11, 2015 01:57 PM
