aeroquip fittings for alloy tanks
Old Mar 2, 2008 | 11:01 AM
ital_cossie's Avatar
ital_cossie
Default aeroquip fittings for alloy tanks
hello,
i have a ford sierra cosworth 4wd and i want to fit proalloy header tank swirl pot separator and oil breather. I saw in PF magazine some cossies that have alloy tanks but not with the silicone hoses but with aeroquip fittings and hoses. I would like someone if can tell me the dimensions of these aeroquip hoses because i've contact proalloy and they told me they will make them for me but they want the dimensions.
waiting your answer!
waiting a final result as this in photo:
thanks
atanasio
Old Mar 2, 2008 | 04:45 PM
Ryan's Avatar
Ryan
Thats -10/AN10 Braided Hose and fittings on the breather system
Old Mar 3, 2008 | 02:17 PM
ital_cossie
thanks,
can you tell me also or make me a design of the total system? where every hose goes? it's necessary to fit also the breather or it's ok with only the separator?
thanks
Old Mar 3, 2008 | 02:51 PM
Ryan's Avatar
Ryan
The breather tank look like a Philloy item, that is a custom setup, specific to karls car.
Its a 4 port system which breathes from (Cam Cover, Inlet Side of Block underneath the inlet, Turbo side of the block underneath the exhaust manifold, and vent to atmosphere or seperate hidden catch tank) There will also be an oil return from the breather i suspect.
steerfromdarear
28
Jan 29, 2016 06:14 PM
Oct 9, 2015 07:38 PM
cossynut2
Aug 19, 2015 11:29 AM
Alloy wheels and ICE for sale
Aug 16, 2015 07:55 AM
155lee
Aug 14, 2015 11:21 AM
