What a f**king morning
Old Mar 1, 2008 | 12:22 PM
cosrep's Avatar
cosrep
Default What a f**king morning
Stripping down the unknown turbo in my mates 2wd saff and 2 of the turbo to manifold studs snap, managed to get one out with a stud extractor but the other isn't going any where, its "waisted" down to less than 6mm so the stud extractor wont grip it any more, tried heat and a vice grips but that just snapped it off...
Then 3 of the 6 bolts that hold the turbine housing on snapped, whilst drilling a pilot hole in one the bit snapped and is now jammed in there. Got a hole drilled in another and then the "hardened steel" screw extractor snapped in it....
Is the turbine housing scrap...???
Old Mar 1, 2008 | 01:06 PM
Can you not take it a specialist engineers and see what very can do with it.
Old Mar 1, 2008 | 01:29 PM
AndyPen's Avatar
AndyPen
I think a spark eroder will remove pretty much anything if you know of someone with one? I had the same prob on the 'trousers' part of my manifold and they got it out.
Old Mar 1, 2008 | 04:51 PM
A spark eroder would certainly do it, down to 1/4mm size hole!!
Old Mar 1, 2008 | 07:22 PM
155lee's Avatar
155lee
how about my day,tightening the timing belt pulley,couldnt get it tighter than 12nm,then pulled the stud out of the head,got my pal to helicoil it,then i broke the coolant temp sensor.i did want to take it out tonight!i kicked the wheel in disgust then slammed the door while muttering.i hate it sometimes.
Old Mar 1, 2008 | 07:38 PM
trevCOSS's Avatar
trevCOSS
this happened to me yestreday although mine was 30nm max, needed helicoiling as well but im still waiting for a new stud and nut to arrive
Old Mar 2, 2008 | 09:09 AM
155lee's Avatar
155lee
Mine Was Like That Before I Touched It,it Came Undone Really Easy Which Made Me Suspicious.i Heard Of Somebody Having Their Engine Wrecked By The Stud Pulling Out Of The Head So I Was Really Wary When Tightening It Up.i Dont Have A Special Engine But It Would Really Annoy Me Having To Rebuild It Because Of That Happening.least Thats 1 Thing Sorted,just Hope The New Sensor Arrives Tomorrow So I Can Take It Out To See If Everything I Have Done Is Ok.ordered It On Monday From P.j Motorsport And Still No Sign Of It!
timsrs
Nov 13, 2018 11:48 AM
Fiddy
21
Sep 29, 2015 06:10 PM
pabloXR
Sep 21, 2015 12:42 PM
Alloy wheels and ICE for sale
Sep 19, 2015 07:50 PM
