weight of saph cossie
Old Mar 1, 2008 | 04:27 AM
coachworz's Avatar
coachworz
Default weight of saph cossie
anyone can tell me how heavy is the sapphire cossie? thanks
Old Mar 1, 2008 | 04:48 AM
indycos's Avatar
indycos
helooooo!!!
here:
kerb weight: 1280kg (2816lb) add 10kg (22.05lb) for cat model
Old Mar 1, 2008 | 05:11 AM
MARCOSWORTH's Avatar
MARCOSWORTH
Depends on which model,my 4x4 non cat. with aircon is 1310kg
Old Mar 1, 2008 | 05:30 AM
indycos's Avatar
indycos
helooooo!!!
yep sorry, failed to mention the information i put up is supposed to be for the 4x4 model
Old Mar 1, 2008 | 05:39 AM
2wd according to ford brochure is 1230KG.
I had mine on mates workplace weighbridge, with full tank of fuel at 1197KG, then I got in, but can't tell you how much it went up by!!
Old Mar 1, 2008 | 07:50 AM
coachworz's Avatar
coachworz
thanks.. saw the metal plate in engine bay that say 1700kg!
Old Mar 1, 2008 | 04:20 PM
Moonstone Mart's Avatar
Moonstone Mart
took mates car to work for MOT and randomly noticed the brake weights chart. thats listed cosworths as 1440KG.
Mart.
Old Mar 1, 2008 | 08:56 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Mine was re-weighted when it was imported to Holland and saw 1340kg.. That's a 4x4.
Old Mar 2, 2008 | 02:41 PM
TurboShed's Avatar
TurboShed
Cossiemodo
So is it worth trying to lighten one?? What kind of weight does a carbon bonnet save? Any other good ways to lighten one up?
Old Mar 4, 2008 | 08:37 PM
tracktoy2006's Avatar
tracktoy2006
My mate is currently stripping his 2wd as its going to be used for trackdays, he needs another set of lowering springs to drop it even more now as so much weight has been taken out.
unless your going to that extent i doubt its worth it.
wowk
Mar 30, 2021 07:49 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Russ Payne
Sep 25, 2015 08:29 PM
